can't find image display in the IMAQ Vision control palette
Hi
I am trying to display an image on the front panel. But i cannot find the image display vi .. according to the manual, it is available from the IMAQ Vision control palette. I have the academic version of LabVIEW 7 express. Does my version have the vi? Thank you
rsa..
(3,247 Views)
Hi RSA..
Frontpanel => Vision => Display Image
did you install the vision toolkit/drivers or just labview express?
you can also display images with graph => control => images
(3,239 Views)
i think it has all vision toolkits except for this one... the labview our school provides comes with IMAQ toolkit .. I am not sure if that's what u meant..
(3,236 Views)
just have a look in the license manager,
is there the vision module active?
regards timo
(3,228 Views)
if i found the image display control on another computer ( but student version of labview) can i copy the dll files and use the control on my laptop? Thank you
(3,204 Views)
The IMAQ Display control is a part of the NI-IMAQ driver. This driver is free of charge and can be downloaded from our website by going to www.ni.com/download. Here is a URL directly to the current version of IMAQ: "http://digital.ni.com/softlib.nsf/websearch/CD7EAFE90E9E47398625703000754A12?opendocument&node=132060_US". If you plan on using that control, I would recommend just installing the driver for it on whatever computer you want to use it on.
Aaron B.
(3,191 Views)
