can't format the tables in LabView
Hello, I am the first time working with tables in LabView and have a problem with formatting the table.
I couldn't find about this in helps or in this forum. How can I format the table, such as change borders,
or merge cells?
(3,297 Views)
You can't change the cell borders. If you want to merge cells, you can realize this programmatically, also append a cell to another cell.
Regards
MY
(3,291 Views)
Can I import already formatted table from another program, for example, from Excel or Word and use it in LabView?
(3,286 Views)
Here ist a similar topic discussed sometime ago:
http://forums.ni.com/ni/board/message?board.id=170&message.id=422958&query.id=228879#M422958
Regards
MY
(3,284 Views)
