can't get strings property on enum
In the attached sample.vi, I'm trying to obtain a strings property of the enum so I can use the string data in a string indicator. From my readings I'm led to believe I should be able to right click on the enum and select Create>Property Node>Strings? But Property Node isn't an option (see attached .jpg). How do I get a string property from this enum?
(3,226 Views)
You can't get a property to a diagram constant.
I can think if two options
1) Wire the enum constant to a "format into string"
2) Change the constant to control, create the property node as you tried previously.
Option #1 is preferable.
have fun!
Ben
(3,220 Views)
Thanks much Ben. I understand now.
(3,210 Views)
