can't open the attachement
K seeker,
Thanks for your quick reply but I cannot open your attachment
(2,389 Views)
First of all, you should replay on the same thread instead of creating a new one. It makes it difficult to know what your're talking about.
K seeker did not send an attachment. He gave you the path to one of the shipping examples that should be installed on your pc. The other way to find examples is to go to the help menu and select Find Examples. If you go to the Search tab, you can enter Graphs and a whole bunch will be seen that you can look at. You should also read chapter 11 of the LabVIEW User Manual.
Multi-plot graphs are simple. They are a 2D array of either waveform data types or numbers.
(2,389 Views)
