can't run a built application because it can't find Run-Time engine
Let's start at the begining.... everything was working fine, and then I started getting an error 2 (memory is full) while compiling any application.  I couldn't resolve the issue but the same applications would compile on another machine, so I uninstalled every National Instrument software from Control Panel (add remove programs), and deleted the c:\Program Files\National Instruments directory.  I then reinstall the Labview 8.0 Prof Dev system,  and performed the labview 8.0.1 upgrade.  I can now open and compile applications,  but now when I try to run one of the compiled applications it says it can't find the labview 8.0 or compatible run-time engine....  I tried to install the runtime engine, and I get an error message saying a higher version is already installed so it won't install.... when I go to control panel the runtime engine 7.0 and 7.1.1  show up , but Runtime 8.0 or 8.0.1 do not....   I installed runtime 8.2.1 to see if it would show up in the control panel 'add remove programs) and it does not .....
help!
thanks
Mike
(2,540 Views)
Mike,
This knowledgebase may help you
Regards
Ray Farmer
Regards
Ray Farmer
(2,532 Views)
