05-10-2011 02:24 PM
I'm trying to read in serial data from an Arduino Uno board that's connected via USB on Windows. I have the driver installed, and the Device Manager in Control Panel shows an "Arduino UNO (COM3)" listed under Ports (COM & LPT). Furthermore, the serial monitor in the Arduino software is succesfully displaying values read from the board.
However, when I tried using the sample VI posted here (serial_arduino3.vi):
http://ni.i.lithium.com/t5/LabVIEW/Writing-terminal-COM-data-to-graph-using-Visa/m-p/1511430
I could not change the COM port in the front panel - only COM1 was listed, and when I clicked on "Refresh" nothing happened.
any suggestions?
thanks,
imran
05-10-2011 02:45 PM - edited 05-10-2011 02:45 PM
Can you see it in max? Also have you just tried typing com3 into the control?
05-16-2011 12:08 PM
Hey Steve,
i've fixed the issue - it turns out I hadn't installed the NI VISA drivers, and vmware was causing all sorts of USB weirdness.
thanks!
