can't set background color of boolean
I'm trying my hand at a custom control.  It's a simple boolean 'arrow' indicator.  I started by placing a classic "flat square button", then imported the 'false' and 'true' versions of the arrow, which correspond to red and green.
However, I want a 3rd state (off).  To accomplish this, I tried to use a property node, but it doesn't seem to work.  I created  a simple VI to test with, I've pasted the image below...I know the event structure is being executed, because I tested that by changing the boolean text inside the event structure.  To prove it can be done, I set every value of the array to blue, just to make sure I wasn't missing something about the true/false/t->f/f->t arrangement of the array.
But all to no avail...I can click on the control and it changes from red to green, like I originally defined in the control.  Why can't I programatically change the color?  thanks in advance
(2,922 Views)
ed up just using a picture ring and just pasted in the 3 different options I want.  Seems to work fine.
(2,909 Views)
bmishoe wrote:But all to no avail...I can click on the control and it changes from red to green, like I originally defined in the control.  Why can't I programatically change the color?
It is probably more likely that your imported pictures are just covering the background of the button.
A picture ring is the better way to go anyways.
(2,903 Views)
