can't use traditional ni-daqmx on LabView 8.2
Hello again,
just to be clear what I exaclty have:
iMacs with WINXP and MAC OS Tiger selected during booting.
I installed from the "NI Academic Site License 2006" the 8.2 core software on WIN XP and installed the "LV Professional Development System for MAC OS X 10.3 or later" on Tiger.
If I now open a blank VI on WINXP and open on the Block diagram the functions menu and go to measurement I/O I see what can be seen on "WINXP.jpg". So there is all I need except the traditional VI's.
If I do the same on the MAC Tiger version after or before the mass compiler, I do see an empty window under Measurement I/O. So there is no VI at all and I have no clue why? I am used to the old LV5-7 and have no clue what I did wrong.
Message 11 of 15
(857 Views)
It looks as though you have not installed NI-DAQmx Base. See my previous post.
Unfortunately, NI does not seem to be trying very hard to make DAQ on Mac easy.
Lynn
Message 12 of 15
(854 Views)
Thanks again. The strange thing is I can see the NI-daq base folder on the LV 8.0 on which I installed 8.2, but now I am downloading the base 2.1 for XP and Tiger again and I hope it will help. Additionally I am downloading Legacy, which I did some while ago. Maybe a fresh installation will help 🙂
Message 13 of 15
(850 Views)
I installed NI DAQmxBase on both WinXP and Mac OS Tiger running on our iMac computers with Intel processor. Now, finally, both versions show the VIs in MEasurement I/O. However installing LEGACY was not possible on the MAC, because after unzipping the file, I couldn't execute it. On the other hand LabView support told me, that USB-6009 is not supported by Traditional DAQ, so there is maybe no need to install it.
But shouldn't it still be possible to see the traditional VIs even if I cant use them in cunjunction with the USB 6009?
What I tried was downloading complete/NI-DAQ_6.6.x_4.9.x(full).hqx (that was suggested by the support), but after unzipping no execution is possible on the computer. I tried it on my personal MAC without Intel processor and it told me that Mac OS Classical environment is needed.
So how can I install Legacy on a intel based MAC? All other questions are somehow answered, I will change the traditional VIs to the new ones in order to use the USB 6009, which should be so difficult using the template.
Message 14 of 15
(822 Views)
The legacy NI-DAQ is not supported under OS X. You can load it under Classic, although I do not recall if it runs. Classic is a MacOS 9 environment runnig under OS X on PPC. Because of hardware differences Classic does not run on an Intel Mac. I do not believe there is any way to run NI-DAQ on an Intel Mac.
You certainly do not need NI-DAQ for any hardware that is supported under OS X. The USB-6009 runs quite nicely on PPC or Intel Macs with DAQmx Base and LV 8.20. I have not run the 6009 under earlier versions of LV but LV7, 7.1, 8.0, and 8.2 all see the DAQmx Base VIs.
Lynn
Message 15 of 15
(812 Views)
