can't write to strict typedef with Control Value:Set [Variant]
Hey everyone,
I inherited a project that uses stacked strict typedefs for the front panel, and I need to programmatically change one control, and it is within an event.  However, the control is a strict typedef in a strict typedef, and Control Value:Set [Variant] has no effect on the specific control.  I have gotten the method to work in small test vi's without typedefs, so I'm pretty sure that is the problem.
The only thing I can think of is that there is a unique way of referencing the control name through typedefs, and I don't know it.
Any ideas?
Thanks in advance,
Jeff
(2,730 Views)
Jeff,
A property node created for the control you want to change should work. I have used them to set elements of typedefs within typedefs.
Obtaining such a property node programatically can be complex. You may need to use the To More Specific function to obtain the references needed.
Lynn
(2,717 Views)
Lynn,
Thanks for the reply.  It turns out that to programmatically Control Value:Set [Variant] bundled controls, you can only pass in the top level bundle control name.  It took some tricky placement around my structures, but I eventually unbundled and bundled by name from the top level down to the bottom and back up to make it work.
Thanks again
 - Jeff
(2,703 Views)
