Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
can the dataSocket server be run on Linux?
macsmith
Member
02-11-2003
09:34 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
newbie q: does the dataSocket server work on the linux version of labview? If so, how is it enabled? If not, what are the alternatives if any?
0
Kudos
Message
1
of 3
(3,111 Views)
Reply
Re: can the dataSocket server be run on Linux?
ebarker
Member
02-12-2003
09:40 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The DataSocket Client works on Linux, but not the DataSocket Server. You will need to run the DataSocket Server off a Windows machine.
0
Kudos
Message
2
of 3
(3,111 Views)
Reply
macsmith
Member
Author
02-13-2003
01:28 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Does anyone at NI know when the datasocket server will be ported to Linux. We're trying to build a linux only system. The lack of a linux version of the server puts a hole in our attempts.
0
Kudos
Message
3
of 3
(3,111 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
