can the sbRIO-9651 surport the canOpen communication protocaol?
I kown we can use the NI-Embedded CAN for RIO driver on 9651,but can  this  driver surport the canOpen communication protocaol  driver?
(2,396 Views)
Hi zhgwangpeihua,
sbRIO-9651 doesn't support the CANopen communication protocol. You can get detailed information from the following link:https://www.ni.com/en/support/documentation/supplemental/13/supported-hardware-and-software-for-ni-i....
Thanks!
(2,380 Views)
Hi zhgwang,
as CANopen is based on CAN you can always implement your own CANopen protocol driver…
(It's a lot of work, but clearly helps to learn all the internals of CANopen.)
There used to be an example implementation of a CANopen driver for FPGA somewhere at NI's website, so search or ask your local NI support for help!
(2,318 Views)
