can version 7.1 work with a PCI-6024E?
Hi! I've been trying to run a VI which is being successfully used in my lab to acquire data. However, whenever i try to run it i get stuck when the AI Waveform Scan VI file is being searched. Following your replies to similar questions i've made sure that the traditional NIDAQ is properly installed. is it possible that my data acquisition card (PCI-6024E) cannot support ver. 7.1? what do i do next?
Tamar
(2,574 Views)
I kind of remember, we have a system with a 6024E board (maybe 6032E), and the LabVIEW is upgraded from 6.X to 7.X, until 8.X.
------- LabVIEW 2009, So Easy, Even a Therapist Can Do It -------
(2,560 Views)
from what i understand from your post, your problem has nothing to do with the card.
your vi cannot run because a subvi is missing: AI Waveform Scan. it is probably in a different library than on the original computer (i would guess the original computer has a different version of LV installed). maybe it is one of the examples in a previous LV version?
Either way, the easiest solution for you is to go to the original computer, save your vi with all dependencies (as an llb for example), and try again on the new computer.
... And here's where I keep assorted lengths of wires...
(2,554 Views)
