can we connect inductive pickup with ni9219
sir
i have a inductive pickup of HBM company. for measuring low frequency measurement. can i use ni 9219 module for measuring output from the sensor. i m not getting whether inductive pickup gives output in voltage or current. or just tell me no. of different modules which we can use with inductive pickup. it has 4 wires output in which 1 is for earthing only. if we can use 9219 with this then tell me the cnnections.
mpsingh
(3,188 Views)
Hi Mr M.P Singh,
Generally inductive pickups give the sensor output in mV. Since NI9219 has a large voltage range of 250Vrms, you can look for other modules with lower voltage range. Also, some signal conditioning would be required as per me.
Hope this helps you.
Best Regards,
Shivam Awasthi
(3,156 Views)
can u give me any usb module no. which we can use with inductive pickups
mpsingh
(3,141 Views)
as u told inductive pickup gives output in mili volts then please tell me how we can use and how we can do signal conditioning with its output.
mpsingh
(3,017 Views)
Did you refer your other thread?
(3,005 Views)
