can we read DLL build in Labview which contains Modbus functions into Visual studio?
I build DLL which contains Goop Modbus functions used for reading data from controller in Labview.
Now I want to use this DLL and read value in visual studio C# .Net. How I can do this?
I kept all modbus settings constant. So my function returns value directly for temperature.
You can check attached code and DLL for same
Associate Engineer
Eaton Technologies Pvt. Ltd
(2,909 Views)
http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/building_a_net_assembly/
Refer to Calling the .NET Interop Assembly from Another Program section.
Also not sure why you have a while loop in your program!
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,900 Views)
Actualy I we executed small function which perform simple addition of two number entere.
Now issue is we are getting error for this particular DLL which has modbus communication VI.
Should I need to install some driver or implement communication separately in Visual Studio?
Associate Engineer
(2,891 Views)
