can we simulate a rs 232 bus using an fpga module
i would like to replace a communication bus (UART, baud rate - 200K) with FPGA card(7831). is it possible to simulate this one???
(3,047 Views)
Yes, check out the RS-232 Interface Using the LabVIEW FPGA module on the Developer Zone. You can also find additional examples and tutorials for the LabVIEW FPGA Module here. You may need to modify the application to get the specific rate that you need but that rate is attainable.
Good Luck
Mike
(3,047 Views)
