can we zoom in/out in LabVIEW?
Hello
I now, in the past, labview couldnt zoom in/out (by reading the last topics). is it impossible yet?
I want make a program, that user can zoom in/out page.
Best Regards
Message 1 of 20
(5,455 Views)
@behzad1 wrote:
Hello
Best Regards
There's no inherent function for that, but if your application should have that ability you can create it yourself. You can e.g. take a screen capture of your front panel and scale it up and show it.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 20
(5,426 Views)
Hi Yamaeda and behzad,
you can load a picture in the 2D picture indicator and set the scaling factor of the indicator using a property node…
So there is an inherent function!
Message 3 of 20
(5,415 Views)
Nice workaround, i like it.
/Y
Qestit Systems
Message 4 of 20
(5,390 Views)
thanks friends
but, we talk about monitoring program as real time. can it scalable?
can we change scale of an object too?
Best Regards
Message 5 of 20
(5,364 Views)
Hi behzad,
you can make your FP scalable, LabVIEW supports that. Learn about pane splitters and their options…
And yes, you can change graph scales too at runtime using property nodes!
Message 6 of 20
(5,360 Views)
Thanks GerdW.
may you make small example for two object?
Best Regards
Message 7 of 20
(5,351 Views)
Hi behzad,
two pictures of the same VI with different sizes of the FP window. Should be a nice example…
Message 8 of 20
(5,345 Views)
Hi GerdW
May you use a tank that it's scale control by a knob in an example?
Best Regards.
Message 9 of 20
(5,267 Views)
Hi Behzad,
please provide an example VI with this tank and knob (in LV2011 please) and tell us, what should be scaled with FP size…
Message 10 of 20
(5,234 Views)
