can you create a point by point chirp signal?
Hi David
Ive being trying to understand how your program is suppose to work but I cant figure out how the chirp array works. I tried to configure it to play sound but Ive had no luck. would you mind explaining the essence behind this generator please? I have uploaded what I have tried.
Cheers
Message 11 of 12
(626 Views)
The detailed information about how the chirp function works is found in the detailed help. Are you able to generate a sound aside from using chirp pattern?
If the sequence Y represents Chirp Pattern, the Chirp Pattern VI obtains the elements of Y using the following equation:
yi = A*sin((0.5*a*i + b)*i)
for i = 0, 1, 2, …, n – 1
where A is amplitude,
a = 2(f2f1)/n,
b = 2f1,
f1 is the beginning frequency in normalized units of samples/cycle,
f2 is the ending frequency in normalized units of samples/cycle,
n is the number of samples.
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
Message 12 of 12
(608 Views)
