can you guys help me make a flow chart of my VI?
Thankyou in advance
Message 1 of 12
(4,561 Views)
Hi Stem,
Yes, in generel we can do this!
Why should we here?
For this special case we cannot help you since you forgot to attach a subVI "converter.vi". (Next time please use ZIP to put all needed files into just one download!)
General comments on your VI:
- Why do you have 30+ cases in your case structure - and the only difference is a simple numeric constant? Why do you duplicate the code in your VI so many times? Use either a ring for the selection of the numeric constant - or an array lookup table!
- Why do you need to convert hours, mins and seconds all on their own? Why don't you create an array of LED clusters?
- Why do you use such an "interesting" background color for (each part) your block diagram? It's hurting the eye when I have to look at a light-purple screen!
Message 2 of 12
(4,531 Views)
We are making an international clock, the thing is i want to have a flowchart  of my vi. The converter sub vi is now included in the zip file. Thankyou!
Message 3 of 12
(4,482 Views)
Hi Stem,
Yes, thanks.
But you didn't do any of my previous suggestions (including changing that ugly background color.)
Then you need to draw it. Use a tool of your choice!
You need sybols for a loop, a comparison, and a data conversion. That's it!
(As it's your VI you surely know how the DATAFLOW is working in the VI…)
Message 4 of 12
(4,474 Views)
but im having a hard time make a flowchart of my vi i dont know what to do and where to start 😞
Message 5 of 12
(4,453 Views)
Just break down each section of your code and make a block for it on your flow chart.  Sections I see are getting the current time, adjusting the time, getting hours, minutes and seconds, and finally configure the display.  It would be a lot simpler if you followed GerdW's advice in simplifying your code first.
GCentral
Message 6 of 12
(4,449 Views)
Isn't this kind of backwards?  Kind of like creating a mechanical drawing from the part?
Bill
CLD
(Mid-Level minion.)
Message 7 of 12
(4,440 Views)
WhiteStarUML can e.g. be used to draw Flow charts, if that's the question.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 12
(4,417 Views)
Yes it is.  But that is the situation the OP is in.
But after some sleep, the better advice would be to draw up a flow chart to show what the program SHOULD do and then update the program based on that.
GCentral
Message 9 of 12
(4,409 Views)
A Corollary to the often ignored Programming Maxim of "Write the Documentation First" is "Develop a FlowChart (or at least a firm idea in your mind of how the Program should flow) First".
Bob Schor
Message 10 of 12
(4,404 Views)
