can you interface labview VI with Altera Max Plus II Baseline
I am trying to create a VI that will supply the inputs and show the outputs for a circuit in the Altera Max Plus II Baseline software. Is this even possible or does anyone have any suggestions of how to go about this?
(3,020 Views)
As of right now, LabVIEW does not interface directly with the Altera software. However, if you can access an Altera DLL or library that controls and displays the inputs and outputs for the circuit, you could call and control that from a LabVIEW application. Please see the "Using External Code in LabVIEW" manual for more information on this process:
http://digital.ni.com/manuals.nsf/webAdvsearch/8D930295FFBF9F7686256D2C00624728?OpenDocument&vid=niwc&node=132100_US
As well as this site:
http://digital.ni.com/public.nsf/websearch/A6705FEC7EA42300862567B70054206E?OpenDocument
Hope this helps!
Liz Fausak
(3,020 Views)
