can you join two hameg dmm's to one labview vi?
One way to save data outside the loop is to right click on the exit tunnel of the while loop and select Enable Indexing. This will create an array that contains all of the readings.
Yes, Excel can calculate the mean, but then so can LabVIEW. I've attached a modified version of your program. It takes the mean of each measurement, appends that to the end of each array, creates a 2D array from both, and then writes all data to a spreadsheet file.
Message 11 of 27
(1,106 Views)
thats great, im still fiddling with this, i will look at your one now. cheers, looks like im finally getting places.
Message 12 of 27
(1,105 Views)
i have a set up like you posted, however im getting nothing past the loop, with indexing enabled. the current and power are all there inside the loop though.......?
Message 13 of 27
(1,101 Views)
I don't understand what you mean. If you have values inside the loop, you will certainly have an array of values outside the loop. What you will not have, however, is values outside the loop while the while loop is running. When the while loop finishes, the array will be there.
Message 14 of 27
(1,095 Views)
well, i put all your code inside the loop, but it asks me to save every cycle. i want to send everything to one excel file in a go. can i hook up the measurement block to the end of the 2 arrays you have gathered up and get the mean that way?>
it doesnt really matter if its inside or outside the loop does it?
Message 15 of 27
(1,092 Views)
NowI'm really confused. The code you posted had a single while loop. Are you saying that you then put that inside another loop? Post this modification if can, please.
The mod I made took the mean of all of the current measurements and the mean of all of the voltage measurements. What exactly do you want to take the mean of?
Message 16 of 27
(1,089 Views)
here is the vi, i just put a measurment vi onto the array output, i was monotoring the data of the array and it was the same as what was coming out of the power string........?
the reason it asked me to save every time was cos i had it inside the loop, but i couldnt get it to work outside the loop.....?! or else it was working but i didnt know it as i saw no activity.
Message 17 of 27
(1,083 Views)
This isn't correct either. You convert a scalar value to an array and then take the mean of it. Because the array will only have a single value, the mean will just be the scalar. You have to do the mean outside the loop or build up an array with a shift register and take the mean each time.
As I said, auto-indexing should work just fine and you can do a single file write and mean calculation outside the loop. If you expect to see activity outside the loop with a probe, you won't untile the while loop finishes, as I also mentioned.
Message 18 of 27
(1,078 Views)
ok, i never know about that activity, that put me off......i was like, what the hell ! so i will go back to your original one again and just export that to an excel file.
i can use the measurement block i like the way it puts in time....
thanks
Eric
Message 19 of 27
(1,073 Views)
i used your idea, everything outside the loop, but again, nothing get saved, just like before......whats happening? freakin hell....!
thats why  i shoehorned everything in the loop before.
what do you think?
Message 20 of 27
(1,069 Views)
