can you program a agilent 8960 rf with labview work?
does labview also work with a rhode and schwarz cmu 200 rf?
(2,958 Views)
If you are using an NI-GPIB board, LabVIEW has a simple set of gpib functions available in the Instrument I/O >> 488 palette. Also LabVIEW and the GPIB driver are shipped with several examples demonstrating simple GPIB applications.
Alternately, if you are using a third-party board, you can either use a VISA distribution compatible with the board or use Call Library Functions to directly access the driver of the GPIB controller. Documentation of the dll should be provided by the vendor.
Ryan Mosley
National Instruments, Applications Engineer
http://www.ni.com/exchange
(2,958 Views)
