canalyzer caple function is not responding (Application.CAPL.CAPLFunction.Call())
I can open canalyzer. Compile the code but not access my own CAPL functions. The program does not report any errors.
The program looks like this.
Message 1 of 10
(10,657 Views)
Thanks for the link. unfortunately it did not help.
I have tried to access CAPL through the com object and python. I get the sama problem. That code look like this
    Application = Dispatch("CANalyzer.Application")
    Measurement = Application.Measurement
    ApplicationEvents = WithEvents(Application,ApplEvents)
    MeasurementEvents=WithEvents(Measurement,MeasEvents)
    CAPL=Application.CAPL
    Application.Open("C:\\Users\\kortOtjock\\Desktop\\Canalyzer filer\\Rig2_Any_Capl_Nodetest.cfg")
    ref=CAPL.GetFunction("TEST")
    Measurement.Start()
    wait(2000)
    ref.Call(1) #thisis ignored by canalyzer
Message 3 of 10
(10,630 Views)
Accepted by topic author magnuslilliehook
Found the problem
GetFunction has to be created in a OnInit event
Message 4 of 10
(10,610 Views)
I need urgent help ...
How is the OnInit() Function called in Python ?
is there an implementation for Python ~2.6 available ? I did not manage up to now to fix the same problem. Maybe someone has a finished implementation for accessing CAPL function by python.
Thanks a lot for your help.
Best regards.
Message 5 of 10
(10,084 Views)
I have the same problem. How to create GetFunction in a OnInit event with TestStand ??
Message 6 of 10
(9,407 Views)
Hey could u jus jot down the code for calling the CAPL function using python .. i am  facing the same problem 😞
Message 7 of 10
(8,850 Views)
OnInit is an event so you must program it right. I don't think it is possible to do it in teststand. Use labview code that you access with teststand. No I don't have any python code.
Message 8 of 10
(8,827 Views)
Hi All,
I have one query regarding the above topic.
How to access the CAPL function in python script and how to execute that CAPL function.
In CAPL function, I am sending a CAN message. I need to execute that CAPL function through python. Can anyone tell me how to do this.
Thanks alot in advance!
Pavan Joshi
Message 9 of 10
(8,548 Views)
Hi ALL,
please how can I get the retuurned value of CAPL function in python below my code any help please:
App_Handle.CAPL.GetFunction("Multiply")
functions_handle.Call()   #this will make a call for Multiply function now how can I get the return value of Multiply
Cordially
Message 10 of 10
(8,379 Views)
