canalyzer previous state
For my CAPL I need to use previous state for a calculation.
For exemple b = a+(a-1) with a-1 = a's previous state and with a and b in float.
I declare my variable a and b but I don't know how to code previous state.
Thank you.
(2,869 Views)
Accepted by topic author ClaireD
You can use the shift register in a for loop and pull down the left side terminal of the shift register to the desired n- states. For your query you can do this way
Good luck
(2,862 Views)
okay. I had not thought of that.
Thank you !!
(2,858 Views)
