cannot close application?
I have an application that allows the user to call and open different windows (other vi's).  When no window or vi is called then i can close the applciation by right clicking on the application instance on the task bar and selecting close.......however when another window is called then I cannot do this, right clicking on the applciation instance in taskbar does nothing....how can i fix this?
thanks
(3,286 Views)
  • Is the subVI window set to "modal"? (e.g. dialog mode)
  • Is the subVI called inside an event set to "lock front panel until event completes"?
(3,278 Views)
Here is a KnowledgeBase article about setting your subVI to modal.
Amanda Howard
Americas Services and Support Recruiting Manager
(3,243 Views)
Thanks, i see my problem
(3,215 Views)
