cannot detect pci card
Hi All,
My setup,
2 PCI card.
Both card are on PC's PCI card slot,
both running perfectly functionally, but sometimes one of the PCI card is not detected.
When the PCI card is taken out from its slot and then Reinserted in the slot the PCI card is detected.
What can be the possible reason for the above.
Shrek
(2,472 Views)
Hey Shrekt,
The thing that immediately springs to mind is that perhaps you don't have a powerful enough PSU, or even possibly a failing PSU. You could try removing a card and seeing if the problem still occurs. What system are you running? Please include the wattage of your PSU.
Regards
Andrew George @ NI UK
(2,434 Views)
