cannot read subpalette text
After installing LabVIEW 2014 Device driver the Measurement I/O --> Measurement and Automation (I guess) subpalette text is a mess. Part is unreadable, part is french and part is german. I remember seeing a post about a similar issue but I can't find it. How can I repair this?
EDIT: My LabVIEW installation is in english.
Ben64
(3,514 Views)
This also affect the LabVIEW Help File.
Ben64
(3,497 Views)
Ben64,
It looks like you have a problem with your System Configuration Palette. Previously when we've seen this issue it has been fixed by repairing the NI System Configuration product.
You can do this by going to your control panel and opening Programs and Features. In the Programs and Features window navigate to National Instruments Software. If you right click you should have the option to Uninstall/Change. In this window find NI System Configuration select it and click Repair.
If you try this and you see no change you can download a new version of the NI System Configuration using this link: https://www.ni.com/en/support/downloads/drivers/download.system-configuration.html#307142
Carli S.
Carli S.
Troubleshooting & Maintenance Digital Business Manager - NI
(3,466 Views)
Thanks Carli, I'm out of office today I will try it tomorrow.
Ben64
(3,461 Views)
