cannot remove tip strips from executable
I recently deployed a large application (v8.6) as an executable.  After deploying it to a machine using a touchscreen monitor, I realized that the tip strips were annoying to the user, so I went into the main VI, clicked on Tools/Options/Front Panel and deselected "Show tip strips on front panel controls".  I then saved teh VI, rebuilt the application and ported it over to the lab PC.  I still get the tip strips.  Has anyone else experienced this?  Is there a setting that I'm missing?  I'm beginning to wonder if the only solution is to go into the VI and remove all the tip strips...
(3,654 Views)
Accepted by topic author DanNatCorning
The setting only applies to the development environment. An application has its own settings. These are saved in the <applicationname>.ini file that resides in the same folder as your application. The setting in the LabVIEW.ini file for having them off would be "showTipStringsOnFPControls=False". I have no idea if adding this setting for an application's settings file will work.
(3,651 Views)
Smurcurio...once again you're a fantastic help. I copied that line of code into the application ini file and it worked like a charm!  Thanks so much!   Now I'm off to read about what other neat tricks I can do with that ini file.  Thanks again!
(3,645 Views)
(3,641 Views)
