cannot run a VI twice in a row
There's a VI that has nested timed loops inside it. If I use the "continous run" button of LabView, it runs fine. However if I try to run this VI through other methods (calling it inside some for/while loo) it only runs once and will choke on subsequent calls. Could this have something to do with an instnace of "VI server reference" that exists inside the code or times loops?
Thanks for your help
(2,905 Views)
You'll have to post some code so we can see what you are trying to do.
The run continuous button is never meant for normal operation of a VI, only for debugging purposes like a subVI, so if that is the only way your VI "works", then something must be wrong.
(2,901 Views)
I have narrowed down the issue to an error that prevents a named timed loop from executing second time the VI is called:
error -816: Timed structure aborted or attempted to execute another iteration of the following aborted time loop.
The VI has an instance of "Stop timed structure VI" that requires a "name" for the timed loop.
Now, I am wondering whether the fact that that name is no longer valid second time the VI is executed could be the issue, so tried to replace that string name of the timed loop with a variable.
Did not solve the issue. Any more ideas?
(2,880 Views)
Still need to see what your code looks like...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,871 Views)
A possible solution may be to trap and clear the error -816. Clearing the error should not change the functionality of your code and allow you to call the VI twice in a row.
http://www.ni.com/gettingstarted/labviewbasics/handlingerrors.htm
Also you might want to read though this forum, the last two post talk about same issue
http://forums.ni.com/t5/LabVIEW/Restarting-counter-in-Timed-Loop/m-p/1419264?requireLogin=False
Tim O
Application Engineer
ni.com/support
(2,834 Views)
Thanks for your response, it turns out the error emanted from a not closed "VI server reference". Once added a close handle, the timed loop does not exhibit error -816 any more. Strange.
(2,817 Views)
