cannot save the excel report in my application
Hi I wrote a program which can save the data to an Excel report. It runs perfectly on my own computer. After I built the application (exe file), and run it in another computer, which can not save the excel report. On my own computer, it has LabVIEW 2011 and report generation toolkit for Microsoftoffice; and on the other computer, I installed the LabVIEW runtime engine. Did I miss installing some other support software? Can anyone tell me why this is not working?
Thanks a lot,
Jane
(2,364 Views)
Do you have Excel installed on the other computer?
I also suggest that you read this page : Including Report Generation VIs in Stand-Alone Applications (Report Generation Toolkit)
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,360 Views)
Thanks for your reply. It's my own fault. I copied the wrong template file. Solved!
(2,357 Views)
