cannot select marker color on intensity
Hi Folks,
I want to add color to my intensity plot, however when I right click on the color map bar, the marker color is greyed out. A picture is attached.  I am using LV2011.
Anyone knows how to correct this?
Thanks.
-Sonny
(4,173 Views)
Accepted by topic author sonny746
Hi Sonny,
What you have to do is actually click on one of the markers first.  Look at the picture I attached.  You can see that I have the value 39.4161 highlighted.  Once you do that, right-click on the marker and you should be good to go.
If you want more colors, you have to add more markers.  This can be done simply by right-clicking on the z-scale wherever you want to add the marker, and then selecting "Add Marker."
I hope this helps!
Jeff S.
(4,144 Views)
That did it!
Thanks.
(4,133 Views)
