cannot uninstall Labview 8.6, get error 1612
I tried to update my Labview from version 8.5 to 8.6 via the online download.  I installed 8.6, but then couldn't get the device drivers because the computer is very old and can't read a DVD.  So I decided to try and uninstall version 8.6 and stick with 8.5 for now.  I began the uninstall using the "Add/Remove Programs" feature, but cancelled it shortly afterward.  When I tried to uninstall again, I get the message "Error 1612 occurred.  Would like to continue this operation?"  All I want to do is completely uninstall Labview so I can reinstall version 8.5 (I have the CDs for that).  Please help!!!
(5,867 Views)
Try searching the forums for a program called MSIBlast. It should help you to remove any NI software you have.
___________________
Try to take over the world!
(5,839 Views)
I got MSIBlast off the forum and ran it.  I selected Labview 8.6 and clicked uninstall, but it said it could not proceed and to select a director where "labview.msi" is located.  I could not find the msi file in my National Instruments downloads folder for 8.6.  It then told me that Error 1612 had occurred again.  Help!
(5,793 Views)
You may try Add/Remove 4Good to uninstall stubborn applications. I've tried this powerful software. It works pretty fine on XP.
(5,736 Views)
