canon powershot s5 image acquisition
Hi.
Am I able to control/acquire images from a Canon Powershot S5 IS digital camera in LV 8.6?
I have managed to get this working with a simple USB webcam, using the NI-IMAQ for USB, but I can't find the Canon camera in IMAQ (it works with its own software).
Is this a driver issue since I think the Canon uses a TWAIN driver?
UniSA, Mawson Lakes, South Australia - LV 8.6.1
(3,309 Views)
You might look at HYtek Automation's PTPCam Toolkit. The link indicates that many cameras are configured as USB storage devices as default. You may need to change your camera to PTP mode in order to see it as an imaging device.
(3,290 Views)
mikie121,
The camera has to be direct show compliant to work with the NI-IMAQdx (or the older IMAQ for USB) drivers.  Like Philip said most personal digital cameras enumerate as mass storage devices and only allow you to add / remove files from them.  Most cameras like this are not direct show compliant.
Sam K
www.ni.com/support
(3,268 Views)
You could try the canon SDK, but I'm not sure it will acquire the image from that model.
http://usa.canon.com/cusa/consumer/standard_display/sdk_homepage
(3,247 Views)
It seems that the camera is configured for PTP mode. However the PTPCam Toolkit doesn't appear to have installed correctly.
I'll keep working on this and hopefully come to a solution.
Many thanks for the helpful replies
Mike
(3,226 Views)
