cant find labview dependancy
I just installed labview 2010 with drivers and when I try to open a vi that was working with lab view 8.6 some depenencies are not found.  The old program uses the Digital I/O card PCI-DIO-32HS but when I try to open the VI that contains DIO Write.VI it can not seem to find it.  Is the driver installed correctly, any suggestions?
(3,590 Views)
Did you install DAQmx?
LabVIEW 2012
(3,580 Views)
DIO Write is from the obsolete traditional DAQ driver and this is not installed by default.
Leave it uninstalled and rewrite with DAQmx functions if your board is supported.
(3,572 Views)
thanks for the information, the board is the PCI-DIO-32HS, would you know if it is supported with DAQmx?
(3,550 Views)
I installed the drivers on the drivers DVD, do you know how to check if DAQmx is installed.
(3,545 Views)
You will have a bunch of vi's under Measurement IO under NI-DAQmx.
LabVIEW 2012
(3,534 Views)
NI PCI-6533 (DIO-32HS) is supported in DAQmx 9.2.3. To find this info, always take a look at the readme included with the driver. We list all hardware that is supported by the driver there.
--Michelle
(3,512 Views)
