captions
Hi HopeH
I probably wasn't clear.   Your example -its good, but it not editable in run mode (directly)     It is selecting from an already written list   Another way to say is what if you didn't know what the user wanted to enter?
Message 11 of 16
(1,132 Views)
So just wire up whatever it is that the user selected. What is the problem you are having with that?
Message 12 of 16
(1,129 Views)
If you are going to allow a user to redefine what a button means, how do you plan to associate their naming conventions with the actual functionality of that button?  Sounds like you might want to limit their options instead before it gets completely out of control.  #users * #options * Upper/lower case * misspelling * ...   Smiley Frustrated
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 13 of 16
(1,125 Views)
yes - i know that HopeH.  I just didn't want to add any more"stuff" if it was unnecessary and the caption itself could be used as runtime text box.  Didn't mean to go so far with this
Thankyou for your thoughts
Message 14 of 16
(1,113 Views)
Ohhhh, I finally get what you mean. You are wanting the user to directly enter text into the caption to edit it. Yeah, I don't think there's any way you can do that... But it's not really much of a complication to add code for how the caption should be set, I don't think, and, as Minions said, you probably won't want it to be exactly as a user typed, but you might want to have them just pick from options to set the caption or something like that. Good luck with your application!
Message 15 of 16
(1,109 Views)
We have several products that have similar interfaces except that they have completely different names based upon the customer.  Based on the interface that connects to the UUT, we have a custom set of captions that appears to the user for each unique product.  We have the captions stored within a configuration file and then load the correct set based on the UUT interface.  This way the look/feel can be changed to accommodate the user; however, the underlying functions and connections are consistent and the naming remains consistent as well once the product is finalized.
Message 16 of 16
(1,101 Views)
