capture video from front panel
My application displays real time TV video on the front panel of my VI using an activeX container. I need to perform an intensity analysis of this signal but can't find a way to convert it to an "image" for use with the IMAQ utilities. Can anyone recommend a technique.
(2,883 Views)
There used to be a program called "camcorder" that came with Office97 that made an AVI from whatever you had on your desktop. I'm not sure if that runs witn Win2000/XP, but it might be worth a try. I'm sure someone has an updated equivalent to Camcorder, as well.
Good Luck!
eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,883 Views)
Try "Camtasia Studio" or "Snagit".
(2,883 Views)
To do this directly in LabVIEW, you will need to obtain a 2-D array of pixel values. You can then use the Vision function 'IMAQ Array to Image.vi.' You can then use any of the vision algorithms to analyze the picture.
(2,883 Views)
