capture voltage when switch input made
I'm reading a voltage input. I would like to grab the voltage when a physical switch is made. Is there an example?
Ed
(3,247 Views)
Try searching the shipping examples for the term "Triggering"
- James
Using LV 2012 on Windows 7 64 bit
(3,223 Views)
Well, close but not quite there yet.
The trigger and gate vi is pretty close. However, since I'm using a mechanical switch input to the manual input of the vi I get a stream off data from the switch close to open.  I tried modifying the rising and falling settings and all the other setting but to no success.
(3,203 Views)
What DAQ card do you have? Some support digital input state change detection. You can set this up in software and poll the input line, and use a Value(Signaling) to trigger an event case to then poll the analog input for it's value. Is the analog signal changing fast? If so there may be some lag between the poll event and the input read.
-AK2DM
(3,201 Views)
