capturing chameleon raw data
I am trying to capture raw Bayer data from a Point Grey Chameleon camera in LabView.
In NI-MAX it shows up as a IMAQdx device.  So I used the "Low level grab raw data.vi" example for the
IMAQdx devices.  But instead of getting just 1280x960 bytes of Bayer data, I am getting 4 times that amount.
The camera supposedly outputs in raw 8-bit (verified with FlyCap2).  I've read other psosts, but haven't come across a similar problem.  Any hint?
I also need to convert the data to an image (Bayer decode) in real-time and store the raw data.
TIA,
Tim
(4,083 Views)
Is that not what you're after?  Each pixel in teh 1280x960 array is composed of an R, G, B, and additional G element... interpolate the data in those components and you'll get the pixel's color.
Normally the camera/micro would take care of the interpolation and just give you the image back.
(4,076 Views)
Thanks.  My problem is that I am supposed to get only 1280x960 bytes for Bayer raw data,
each byte is a color, as you said,
but I am getting 4 times that amount using the "Low-level grab raw data.vi" of IMAQdx example.
Is there another VI for capturing the raw data?
(4,070 Views)
Sounds like you just want the image off the sensor, not the actual "raw" data.
I don't have the full IMAQ toolkit installed, but it should be a straightfoward create-task, read, close-task operation.
(4,060 Views)
After thrashing around for a couple of weeks, I finally got it working thanks to both Pt Grey & NI tech supports.
I'd like to share the solutions to save other people time.
To record Bayer data from a Pt Grey Chameleon (Or any simmilar cam), a IMAQdx device:
- download a newer version of FlyCap2 (2.3.3.19).
- in "Advanced camera settings" tab, select 'default' channel & restore settings of the camera.
- in NI-MAX, for this IMAQdx cam, find "1280x960 RGB8 15.0fps" for video mode, & "mono8" for format in Acquisition Attributes" tab.
- you should see a B&W Bayer image in MAX.  Exit & save the settings.
To save raw data & display decoded color image in real-time, see the attached example,
which is based on the NI's "Low-level Grab Raw Data.vi" exmaple.
(4,007 Views)
