capturing streaming serial data
I have a device that collects data on a sensor and streams information on an RS232 cable to my machine.  When I use the VISA read operation, I can see data is being read, but I get a buffer overrun error since the data is constantly streaming to my machine.  I am used to doing VISA write then VISA read type programs, but never have dealt with constant streaming data.  How can I collect streaming data on the COM port?
thanks in advance.
(4,166 Views)
You may want to look into flow control.  There's a great knowlegebase, Serial Communication with Software Flow Control, that explains how to do flow control in LabVIEW.
Meghan
(4,132 Views)
The easiest way to stream data is to configure your serial port outside of a while loop.
Use a "bytes at port" wired to a visa read inside the while loop.
Close the serial port on the other side of the while loop.
You should put a wait in the while loop so you don't hog your CPU.  Only needs to be a few mSec.
If you need to do any data processing you might what to use a producer - consumer design pattern.
Good Luck
(4,119 Views)
