caractéristique courant-tension
hi,
could you tell me how can i determine exactly the sampling period of my digital data.
thank you.
Message 21 of 41
(2,087 Views)
Your question seems unrelated to the existing discussion of this thread.
You also need to be much more specific:
  • What is the datatype of your "digital data" (array, waveform, dynamic, etc.)?
  • Where did the data come from?
Message 22 of 41
(2,073 Views)
I made an acquisition of data for the current and the voltage,
so I have an array of data and the current vs voltage curve, I would like to draw the derivative, so I need to sample the data.
Message 23 of 41
(2,063 Views)
The sampling period is entirely determined by the acquisition parameters.
Message 24 of 41
(2,052 Views)
ok i have this parameter;
the acquisition was made with this parameter ( 15 bytes per packet, 115200 baude rate ).
Message 25 of 41
(2,042 Views)
These are the serial communication parameters. They have nothing to do with the sample timing (except for giving an upper limit).
Message 26 of 41
(2,028 Views)
my acquisition was done with the interface of arduino and labveiw, so can you tell me what are the parameters you talking about,
Message 27 of 41
(2,018 Views)
Only you know how often you sample the input. If this is not clear to you, maybe you should start with a simpler problem.
Message 28 of 41
(2,006 Views)
I made the  acquisition for 156 points, and the time between two point is 100ms.
Message 29 of 41
(1,990 Views)
anyone can help me to samling the signal.
Message 30 of 41
(1,962 Views)
