cascade control system
I need to build a VI for cascade control of 2 tank system with primary variable as level of tank and secondary variable as temperature of the water
(924 Views)
Ok.
(919 Views)
Forget about LabVIEW.  Think about your Task.  Using Pencil and Paper (or a suitable equivalent, say a computer and Notepad or Word), make a list of the variables, the uses you need to make with these variables, and concentrate on what you want to do.
Once you know that, apply the principles you learned in your Basic / C / C++ / Pascal / LabVIEW course to transform the "input quantities" into the desired "output quantities".
If you get stuck, come back here and show us what you have done and explain the problems you are having.
Please attach your LabVIEW code, and tell us what version of LabVIEW you are using.  Many of us (like @GerdW and myself) do not have the latest version of LabVIEW, so you might consider doing a "Save for Previous Version" and specify LabVIEW 2019 or 2021.
Bob Schor
(892 Views)
