case structure with arrays
why don't the array values are not shown in array 0 and array 1 in the enclosed attchment array0.vi.
thanks
(2,841 Views)
Then default value then NOT wired is an empty array. So using array 0, as an example. It will be filled with data on iteration 0. But this data will be overwritten with an empty array. In the next iterations.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,835 Views)
Use Shift Registers.
Jim
(2,789 Views)
thank you
(2,768 Views)
