case structure
hello,i have the next code in labview,but i have the next problem:
the case structure only is executed one time and i would like that the struture will be executed more than one time in the true case,until the case structure changes to false.
thanks
(2,819 Views)
Sounds like you're describing a while loop
(2,797 Views)
