case structure
I am having problemwith triggering the case structure. I have built a smal ldemo to show my problem. The write to spreadsheet is active no matter if the value is true or false. I want to activate the results beeing written to a spreadsheet by a button. All this is inside a simulation loop. Pleasetake a lookat it.i Have attached a small demo of the problem.
Message 1 of 14
(5,861 Views)
Hi Spatpatia,
this remembers me of a thread discussed a week ago...
In a simulation loop controls will not work as usual! The simulation is like a sandbox running their own business, you have to use other programming schemes to get your desired result...
Message 2 of 14
(5,849 Views)
I suggest a while loop and an event structure with "boolean", "Value change" to run you write to spreadsheet code. (this is outside of your simulation loop)
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 3 of 14
(5,841 Views)
Thatlink didnt help me much i am afraid.Okey what other loopscan i useto be abel to use the memory function?
And i have had servelsimularproblems with the case structure not working in other surcomstances as well where the true and false function doesnt work. How come?
Message 4 of 14
(5,835 Views)
it seems i can use the memory function other then in simulastion loop
Message 5 of 14
(5,835 Views)
Harold could u make that example for me? i am new with LAbview so i dont rem every function and word in it.
Message 6 of 14
(5,833 Views)
hope this helps out a bit:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 7 of 14
(5,826 Views)
Sorry to ask this silly question but howdoes it work and how is it built up. I havent come across of this path symbol before.
Message 8 of 14
(5,818 Views)
I is under modern - string and path
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 9 of 14
(5,812 Views)
Thank found it=)!
Could u take a look at this and see if igot this right?
I haven testedit outyetbut willthe other controls insidethe simulastionloopnot work properly? Should i use a whileloop insead?
This is a system that measures thevoltagefrom a presure sensur and a speedo meter.
Message 10 of 14
(5,800 Views)
