case strucute with infinity and else as two cases
Dear Guys,
I would like you to help me making a case strucutre with two cases ... Infinity and Else how is it possible to make such a case strucutre and thank you in advance..
(4,248 Views)
There is no value assigned in integer which represents "Infinity".
So i understand that you deal with floating point numbers. A simple "Equal" compare of your number to "Inf" will result in data you can use with a case structure....
Norbert
Norbert
Expert: Geometry
(4,238 Views)
You'll have to use a Equal to Inf and have True and False cases. You can't wire a double directly to a case structure for this.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,235 Views)
Pictures paint a thousand words!
(blog)
(4,231 Views)
But VIs are worth a thousand pictures.
Bill
CLD
(Mid-Level minion.)
(4,180 Views)
