case timestamp
I have case structure inside the while loop (time Vi). I want to get the timestamp when the case structure becames true. I just need single time stamp.
(1,895 Views)
Hi oMme,
So you want to get the timestamp when the case condition changes from FALSE to TRUE?
A boolean change is called "edge", and there are rising and falling edges. You want to know the timestamp of the rising edge of your case condition!
Happily LabVIEW comes with a BooleanCrossing function…
(1,865 Views)
Hi, Im beginer in labview. can you please provide the example? i have checked forum but could not find similer problem.
(1,857 Views)
Hi oMme,
Please:
Did you notice those Training resources offered in the header of the LabVIEW board?
I know there are lots of threads about the problem of detecting rising edges in boolean signals…
(1,842 Views)
For good measure, I would also recommend to set the VI properties to "clear indicators when called", else your indicator might show a stale value until the first trigger.
I typically just use a feedback node.
(You might want to tune according to your requirements. For example what should happen if the boolean is already true when the program starts?)
(1,811 Views)
This is where Event Structures work better than polling.
=== Engineer Ambiguously ===
(1,747 Views)
Yes, if the boolean is a user control. In a typical application it is polling of a condition (DI, threshold reached, etc.).
(Just guessing. Cannot look at the original VI posted in LabVIEW 2025)
(1,739 Views)
