cases of case structure
Perhaps there is a "trick" I don´t know:
Is there any way to read out all the cases of a predefined case structure programmatically ? (Background: LV naturally "knows" all the cases of a case structure and you can get a list of all cases by clicking on the case selector during programming - now I want to have this list in an array (or something else) to handle it programmatically in order to show it to the user during program execution ...)
Thanks a lot for any help in advance !
(2,574 Views)
I don't know of any way to get the list of cases programmatically. What we use is some kind of enumerated type (usually as a type def) to select the case of a case structure. You can then use the enumerated type to know what cases are possible.
Rob
(2,574 Views)
