catch mouse hovering over a combo box !
hello all !
is there a way to read values (in real time) from a combo-box while hovering on it's data entries, but not clicking on any of them ?
thanks ahead 🙂
(4,004 Views)
Please see attached.
Best !
J.
(3,994 Views)
That works once you have clicked on a menu item. I am assuming that we are trying to access the menu items before the user clicks.
If so, you could look at using mouse events to show/hide an array which mimics the behaviour of the drop down menu.
See attached.
(3,990 Views)
that does'nt work !
(3,958 Views)
To which post are you replying?
(3,950 Views)
Hi Ian,
Could you attach the "Array Point to RowCol.vi" SubVI?  I think this is what hookso might be referring to.
Peter D
(3,938 Views)
Ah! Thanks Pete - looks like I attached the wrong sub-vi. Sorry!
Lets try again - see the attached.
To give credit where credit is due and to provide support/licensing info, the Array Point to RowCol can be downloaded from LAVA here:
http://lavag.org/files/file/60-array-point-to-rowcol/
(3,931 Views)
