cdaq question
Please only relavent responses,
So i switched my cdaq 9178 to a 9174 and when i try to run any of the VI's that were already created for the cards that were in the 9178 it gives me an error message 201003 so is there a place where i should be entering the fact that there is now a 9174 chassis instead of the 9178 somewhere or if i have to change all the points somewhere i am also using labview 2012
Any advice would be greatly apprecoated
(2,964 Views)
Like MAX (Measurement and Automation eXplorer)?
(2,944 Views)
Are you referencing the chassis by the MAX alias?  If so then you'll need to name the device the same as the old one in MAX.
(2,931 Views)
