cepstrum implementation
Hi all
ive made some vi but im not sure whether is it correct. Exactly, im not sure if really computate CEPSTRUM. Can some competent check it if its not a problem:). in vi is also a mathscript compute complex cepstrum (cceps(a)) but its only a test modul.
im a beginner in LabVIEW so i need some help.
Thanks for help
(2,844 Views)
If you are using a MathScript enabled version of LabVIEW, you can use the built in function:
http://zone.ni.com/reference/en-XX/help/371361B-01/lvtextmath/msfunc_rceps/
There is also an example available here: http://community.ni.com/examples/the-real-cepstrum-debugged/
Message Edited by Phillip Brooks on 08-09-2007 01:45 PM
(2,838 Views)
