change 2D array index value
I am working on 2D array of size 1024x1280 (zero indexing). now i need to change both row and column indexing
row indexing change from (0,1,2,3....1023) to (0.5, 1.0, 1.5, 2.0, 2.5, ....., 512)
column indexing change from (0,1,2,3.....1279) to (0.5, 1.0, 1.5, 2.0, 2.5,........, 640)
I tried with property node IndexVals, but not success.. please help
(4,150 Views)
Have you tried using "reshape array"?
(4,146 Views)
1024x1280 means your array has 1024 ROWS and 1280 columns. The rows start from "0th" element to "1023th" element. I don't get what is "0.5th" element or "2.5th" element?
Care to elaborate what you actually are doing?
(4,143 Views)
Index to an array is an integer, it can't be float.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(4,137 Views)
Ya 1024 rows and 1280 columns, index starts at 0 and ends at 1023, now i want to change this index starting from 0.5 to 512
only change of index
index      element          Index       element
  0               5                  0.5              5
  1              10                  1               10
  2               8                  1.5              8
1023          6                   512             6
(4,133 Views)
Index of an array can't be in float, it's an integer. However, from your problem I see that you want to make the size of your array to half i.e an array of dimensions 1024x1280 INTO 512x640, right?
(4,127 Views)
Try this VI...!!
so by keeping this (attached) VI in between, you may consider that the index has changed from 1..1023 to 0.5..511.5.
(4,112 Views)
